Message 1 of 10
Bereavement
I informed the BT Bereavement team via telephone on 22/6/26 that my father had died. I got a final bill on 29/6/26 showing a refund was due. 3 months later & I have still not received the refund even aftr having made 6 telephone calls in total & I feel exhausted with it all. I have raised a complaint but nothing yet.
Any suggestions of anything else I could try would be greatly appreciated
9 REPLIES 9
Message 2 of 10
Re: Bereavement
Try contacting billing team using message now and they should be able to help
https://www.bt.com/help/contact-bt/account-and-billing/broadband
Normally if the DD was still active they would normally refund to the bank account -unless bank account deleted
Message 3 of 10
Re: Bereavement
Thank you I will try contacting the billing team again.
The Direct Debit was automatically cancelled by the bank when they closed my father’s account which I believe is what normally happens after a death.
Message 4 of 10
Re: Bereavement
Sorry for your sad loss
Contact your bank and explain what's happening..remind them given the situation that's it's obviously upsetting for you
Hopefully the direct debit guarantee will cover it
Message 5 of 10
Re: Bereavement
You may find cancelling the Direct Debit is the issue. Refunds normally go back to the DD bank account.
Message 6 of 10
Re: Bereavement
You are right cancelling the direct debit has caused the issue but that is standard practice by banks when they are informed that someone has died so there has to be another way for refunds as I can't possibly be the only person this has happened to.
Message 7 of 10
Re: Bereavement
did you try the link I posted to use message now with billing as they should be able to help you
Message 8 of 10
Re: Bereavement
Yes I now have a complaint number & told that someone from the resolution team will call me.
Apparently billing cannot successfully override the name on the account when issuing a refund so trying to use BACS to transfer the refund to me keeps failing as the names do not match.
Message 9 of 10
Re: Bereavement
There is nothing any of the forum members will be able to do other than suggest that you make a complaint, I would suggest to the BT CEO, you'll get her email address with an Internet search.
She won't get the email but her Executive Team will and they should be able to resolve this.
Message 10 of 10
Re: Bereavement
Thank you for trying to help.
I have made a complaint & I am waiting for a call back.
