Anonymous
Not applicable
Message 1 of 8
Upgrade from Home Essentials issue
Hi
I've been told that I can't upgrade directly from Home Essentials to Fibre 250 as the system won't allow it even though gfast is available.  Any solutions to this?
7 REPLIES 7
Message 2 of 8
Re: Upgrade from Home Essentials issue
fibre 250 not available on home essentials so need to end home essentials and take a standard cost plan which is more expensive
Anonymous
Not applicable
Message 3 of 8
So if I move onto a standard package first I should then be able to upgrade to Fibre 250?
Message 4 of 8
can you enter phone number and post results remembering to delete phone number
this will show what is available to you
Anonymous
Not applicable
Message 5 of 8
Odd as I've been with BT for nearly a year:
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line
Message 6 of 8
do you have digital voice as that explains why does not recognise number.  try using your address
Anonymous
Not applicable
Message 7 of 8
Message 8 of 8
that confirms GFAST available so try phoning options team 0800800030 or retentions 08007831401 and see if either of them can help change from home essentials to standard package
