Ah, well spotted. I didn't see that.
As has already been pointed out, this is a BT Customer to Customer forum. You are not speaking to BT when you post your problem here nor can this forum resolve your problem.
You have been advised by the moderatos how to contact BT and seek answers to your question regarding your order and its cancellation.
As regards your user name being changed, it was because your previous one was not suitable because it was inferring profanity ie swearing which some people may find offensive or objectionable.
If you had bothered to read the the Terms and Conditions of the forum,
https://community.bt.com/t5/Announcements-Guides-Community/BT-Community-Terms-of-Use/td-p/1375035
which you agreed to by using the forum, and in particular section 6.3d you would have seen the section about profanity etc.
As regards GDPR, your personal details were not changed, the user name for the BT Forum was changed as per the reason given above and by your own account you were informed that it had been done.
