Message 1 of 11
Why does changing my service from Fibre 1 23Mb to Fibre 1 50Mb need engineer visit & new equipment?
Hi
I've looking to change my BT Broadband service from Fibre 1 (23Mb) to Fibre 1 (50Mb), though when I try to place the order for this it's indicating I will receive new equipment, and require an engineer to visit. This isn't really convenient as this is a holiday property and it's really difficult to make sure someone is onsite for an engineer to visit?
Regards
10 REPLIES 10
Message 2 of 11
Re: Why does changing my service from Fibre 1 23Mb to Fibre 1 50Mb need engineer visit & new equ
BT fibre 1 has a speed up to 55mb and if you are only getting 23mb just now that would suggest that is best your line can handle and you are not able to get 50mb connection speed
enter your phone number and post results remember delete number  this will show what is available to you
Message 3 of 11
Hi
Many thanks for the reply, below are the results as instructed:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
High
Low
High
Low
VDSL Range A (Clean)
37.2
24.9
7.7
5.9
20.1
Unavailable
Available
VDSL Range B (Impacted)
36.4
20.7
7.6
5.2
16.5
Unavailable
Available
G.fast Range A (Clean)
Unavailable
G.fast Range B (Impacted)
Unavailable
Featured Products
Downstream Range (Mbps)
Availability Date
FTTP Install Process
WBC FTTP
Up to 1000
Up to 220
Available
1 Stage
ADSL Products
Downstream Line Rate (Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+
Up to 3.5
2 to 6
Available
WBC ADSL2+ Annex M
Up to 3.5
Up to 0.5
2 to 6
Available
ADSL Max
Up to 2.5
1.5 to 5
Available
Fixed Rate
1
Available
SOADSL Products
WBC SOADSL Availability Date
WBC SOADSL 2+
Up to 3.5
2.0 to 6.0
Available
SOADSL Max
Up to 2.5
1.5 to 5.0
Available
Other Offerings
Availability Date
VDSL Multicast
Available
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
Y
SOADSL Restriction
N
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Feed with no anticipated issues.
FTTP is available and a new ONT may be ordered.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Message 4 of 11
thanks
from what you have posted you cannot get any faster connection on your current FTTC connection.  however you can upgrade to FTTP and then you can get faster up to 900mb connection.  if you want to move to FTTP then try retentions team and see what you can negotiate for the upgrade 08007831401
Message 5 of 11
I suspect the change you have requested involves moving to full fibre which will obviously need an engineer to install.
Message 6 of 11
Thanks for clarifying regarding the need for engineer visit.
To be honest I'm not too bothered at the moment by the extra speed, the current speed is plenty enough for a small holiday cottage. It's just our current (old) contract is 23Mb at £34.30, and the new (cheaper) contract is for 50Mb at £29.99. I think I'd be okay with paying the £29.99 and carrying on with the 23Mb speed for the time being.
Many thanks again for help on this.
Anonymous
Not applicable
Message 7 of 11
There's an even cheaper Essential package at 36Mb, or at least it should be cheaper. But you may hit the same issue trying to regrade with enforced FTTP.
Message 8 of 11
@Anonymous
The BT Essential package is for people on Universal Credit which most likely will not be the case here if the OP can afford a second home.
BT Home Essentials Broadband | Universal Credit Broadband
Message 9 of 11
FTTP is available, so any recontracting with your current provider, or migration to another provider will need you to take FTTP and have it installed, which obviously needs someone present to grant access etc , if your circumstances are such that you don’t want or need FTTP installed, and are happy to pay an out of contract price, simply continue on the out if contract deal  you are currently have , it may be more expensive than necessary and provide a slower speed but won’t need you to change to FTTP for the time being.
Anonymous
Not applicable
Message 10 of 11
@gg30340
No, not Home Essential, Fibre Essential.
Despite there being some 170,00 words in the English language, it was beyond BT to come up with two different names for two different services.. For good measure they also called the basic DV phones Essential.
Then when those clever marketing folks sat down to name all of the EE packages what did they come up with?
