Message 1 of 5
Amazon Fire Tablet
Hi. I have got an Amazon Fire Tablet hd 10 plus 11th gen and want to install the norton ap that comes from bt. The setup goes to the google store which I cannot use. Does anyone know if there is a work around?
Thanks.
Neil
4 REPLIES 4
Message 2 of 5
Re: Amazon Fire Tablet
You need to download an app called Downloader from the Amazon App Store then you can sideload Google Play apps
Message 3 of 5
Is that APK downloader? Thanks
Message 4 of 5
No.
it's just called downloader, the icon looks like this.
Message 5 of 5
Thank you.
