Message 1 of 3
Antivirus
I have antivirus installed on 2 macs, one a Air and one a Pro. On the Air a full scan looks at c. 1.2m files on the Pro only 300k. Both are on same level of Mac OS. Both have same full file access settings in privacy. Both have same full scan options ticked, ie all. I have tried deleting and reinstalling the antivirus on the Pro same result. Am I missing something obvious?
2 REPLIES 2
Message 3 of 3
Re: Antivirus
Thank you. Will give it a go
