Message 11 of 19
Re: App not working
10.0.8
Update today does not work
The same issue with 10.0.7 - looped back to BT website to complete profile; then logged out if app when return to it
How can the developers release an update that again does not work?
Message 12 of 19
Re: App not working
@Ryanm353
If you click on the Manage my Hub button it takes you to various hub settings.
Click on the Expert Setting button then the View Expert Setting button.
It will take you to the hubs settings where you will be able to restart the hub.
When doing this you may get a warning about switching to Advance settings and  https. Click to accept https and to go to Advance settings.
Message 13 of 19
Re: App not working
@gg30340
Thanks for your reply! What if I'm not at home though and need to remotely restart the hub? Can I not do it from the app anymore?
Message 14 of 19
Re: App not working
If you are not connected to your home network you will not be able to do it from the BT app or using the BT hubs management pages. Are you sure you could do it before when you were not at home?
Message 15 of 19
Re: App not working
@gg30340 yes I could do it remotely before on the older versions of the my bt app (before this new redesigned app with all the problems) . I'm 100% sure of that. It used to be handy as if I was away from home and for some reason or other the hub needed to be restarted , I could do it from the app itself and it would usually fix whatever the issue was.
Message 16 of 19
Re: App not working
I rarely use the BT app so I was unaware you could do that remotely using the app.
I have had a look through all the apps settings and it appears that you can no longer restart the BT hub using the app without being connected to your hub which obviously means you can not do it remotely.
Message 17 of 19
Re: App not working
I wasn't aware either, so did a quick check and came across this from 5 odd years ago:
BT Community - restarting hub remotely
Message 18 of 19
Re: App not working
Yep, it was indeed a feature and it was so convenient. I hope they bring this feature back...
Message 19 of 19
Re: App not working
Thanks for keeping us updated with this @Ryanm353
Glad to hear the buttons are working again now with latest release of the app.
I've passed your feedback to the team about the option to remotely restart the hub.
Ali
