Message 1 of 1
BT-Norton Remove device
These are the steps below to remove your device.
  1. Log in to My BT
  2. Select Your Security in the top menu bar
  3. Find the BT Virus Protect tile and select Manage
  4. Go to the Device Security page
  5. Click the More options icon (. . .) below the device you want to remove
  6. In the menu that appears, select Remove Device and click Remove on the confirmation screen
But recently, the remove device is not an option, the only option that is now showing is Rename.
