Message 1 of 3
BT Wifi Hotspots - Can't log in
Our village has a BT wifi hotspot.  I am offered to connect to it in the wifi settings on my iphone, but when I enter my BT user name and password it does not accept them.  What's going wrong?
2 REPLIES 2
Message 2 of 3
Re: BT Wifi Hotspots - Can't log in
Are you using the BTWifi app. If not try downloading it and set it up with you details.
Message 3 of 3
Thanks for your reply - no, I was just using the Wifi setting on the iphone.  I shall download the BT app and give it another go!
