Message 1 of 6
Anyone know when BT will fix the app issue? Been unable to access Your Products for 2 weeks! If I don't use app it's ok. Obviously I've tried re installing but makes no difference. Just a message from BT saying they're working on it!
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: BT app
@Clarkatron  I get same message on the app . I thought it was just mine.  Typical BT take an age to get anything done.
Message 3 of 6
Re: BT app
I know! It's definitely not just you!
Anonymous
Not applicable
Message 4 of 6
Re: BT app
@Clarkatron   Mine seems to be working now.  Must have been something we said.
Message 5 of 6
Re: BT app
Yes. Fingers crossed!!
Message 6 of 6
Re: BT app
Same here, I’ve phoned BT a few times to try and sort out / complain as well but no joy.
Very annoying, before upgrade, it all worked fine on the app.
