Message 1 of 4
BT cloud for mac
I have an iMAc with OS 10.13.  BT cloud recently updated but the newer version is incompatible with 10.13.  I cannot install 10.14 and cannot find an old version to re-install.
Any ideas?
3 REPLIES 3
Message 2 of 4
Re: BT cloud for mac
You can do it manually via Safari but that's not much good it it's a full back-up you want.
Message 3 of 4
Hi Dode,
I'm not sure how this is done manually via Safari.  What I am trying to do is install a BT  Cloud version that is compatible with OS 10.13.
My version was fine untill yesterday when I updated following some prompting.  The new version installed (22.8.10) - and then wouldn't open due to incompatibility with 10.13.  And there are no otions to install an old s/w version of BT Cloud.
Message 4 of 4
To do it Manually go to - My BT> Your Products> Broadband> BT Cloud> BT Cloud in you browser. From there you can organise, upload or download your files but it would be slow trying to do a full backup that way. It might do you until BT get round to producing a compatible version.
