Message 1 of 11
My BT app
I would like to know when using the “My BT” app and clicking on  “your wi-fi network” and then “control wi-fi access for your devices” there are several UNKNOWN  devices showing.  But when I log into 192.168.1.254 on my PC, these UNKNOWN  devices are not showing anywhere?
I have tried deleting the “My BT” app and reinstalling and signing in again but still UNKNOWN devices are still showing in the app!
Any ideas?
10 REPLIES 10
Message 2 of 11
Re: My BT app
Hi, @andreaferns120472 welcome to the community and thanks for posting. Have you tried googling the MAC addresses of the unknown devices as that will often help you find out what they are?
Neil
Message 3 of 11
Re: My BT app
I’ve updated the iOS My BT app to the latest update and there’s no keyboard available so that I’m unable to login to our account.
Message 4 of 11
Re: My BT app
Hi @Brucemeister5 I haven't seen any other report of that problem, it's also working on my iOS device without an issue. Have you tried powering off and on your device to see if that helps?
 Neil
Message 5 of 11
Re: My BT app
I turn my iphone off every night
Message 6 of 11
Re: My BT app
Hi @andreaferns120472 that message was meant for @Brucemeister5. I'm sorry for any confusion
Neil
Message 7 of 11
Re: My BT app
Thanks @NeilO. I’ve resolved the issue now by following your suggestion. Thanks again.
Message 8 of 11
MY BT APP
Any ideas?
Message 9 of 11
Re: MY BT APP
I have many many unknown devices (today it's twelve);  it has been a game of cat and mouse to work out what they are (in the very unlikely event of an unknown device/or actor accessing my network).
Some pointers -
If you have wifi discs, narrow down the device x disc; then look carefully as to what devices are likely to be connected and block each one/test/unblock individually to try to work it out
See if 2.4 or GHz- again can help identify
Change to always use this IP address then try to find out by MAC address
- Remember, some devices *may* reconnect on a new mac address and some of the unknowns (especially when unconnected) are legacy connections.
Hope this helps
Message 10 of 11
Re: MY BT APP
Its probably due to MAC address randomisation on your Apple device,.
