Hi Alex,
I used a call back link on Tuesday as I can't seem to get through using the 150 number.A nice lady called back and spent two hours trying to get to the bottom of the issue. I had to leave, she said she would keep working on it. It was clear however she was no nearer a solution but did try. I recieved a text this morning to say as they haven't heard from me the complaint is closed although I have been in contact several times. It is clear to me that this hasn't reach the right person who can seriously tackle the issue. One of the reasons for going with bt was th cyber protect. which is just not possible at present. Feel very frustrated. Clearly there is an issue with my account interacting with the bt app. Regards, Mike
@Chassis_001 Thanks for the update Mike, I am sorry things seem to have been left without either a resolution or something being raised for further investigation.
I have sent you a private message to see if we can help further.
Alex
Okay, thank you.
I will give it a go. Do I ask for anyone or have a reference ?
@Chassis_001 As per our private message, there is nothing else you need to do at the moment, our team will be in touch and be aware of the issue you are having to help further.
@chrisjp I appreciate what you are saying, especially when each individual step is listed out it seems long winded, but when using it the digital menu is pretty straightforward and gets you through to the right department quicker. But you can still use option 2 when calling to use the traditional audio menu.
Alex
@Chassis_001 Unless you are having a separate issue you need help with, you don't need to give us a call at the moment and use the diagnostics bot. Our team will be in touch as soon as they can to help with the app issue you are having.
Alex
Good Morning, its been a while and I haven't had any feedback regarding my issue. Can so.eone confirm it is going to be looked at and resolved. Thank you
