Message 1 of 5
I cannot get into my bt app on android. I have changed the password a few times. It comes up 'sorry. Something went wrong. Please close the app and try again later.
Any advice would be appreciated.
4 REPLIES 4
Message 2 of 5
Re: Bt app
Hi, @Juliec123 I'm sorry you're getting an error when trying to log in to the app. Do the same BT ID login details work on the MyBT website?
Neil
Message 3 of 5
Re: Bt app
Hi Neil
Again an error message comes up
Message 4 of 5
Re: Bt app
@Juliec123 Thanks for trying that, it sounds like there could be a fault with your BT ID credentials. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to help.
Neil
Message 5 of 5
Re: Bt app
Thanks Neil.  Much appreciated
