Message 1 of 4
Can i manage my home hub network from multiple devices
Hello
I have set up our whole home networking using the app on my phone. If I am away then my partner cannot manage the hub e.g., create a guest log in. What will happen if we add the app to his phone? Can we link two apps to the same network or will it all come crashing down?
Thank you
m
3 REPLIES 3
Message 2 of 4
Re: Can i manage my home hub network from multiple devices
You can't create a guest network on a BT hub nor can you manage it remotely
Message 3 of 4
Access the hub via a web browser on the other phone. Same hub password. Should be no problems.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 4 of 4
thank you
