Message 1 of 11
Can’t open BT Norton on my iMac.
I have reinstalled Norton security to my iMac (OS Monterey v12.6) and when selecting the Norton Icon it is showing "Norton Security Pending" and does’t move on.
10 REPLIES 10
Message 2 of 11
Re: Can’t open BT Norton on my iMac.
This has been covered numerous times, use the search bar above
Message 3 of 11
Hi, Thanks for your reply. I did a search for “Norton Security Pending” but didn’t see an answer to fix this problem.
Message 4 of 11
Message 5 of 11
Hi @Terry_Artdeco and welcome to our community.
Thanks for posting about the Norton on your iMac. I'd be interested to know if the link posted by @Les-Gibson helps. Can you get back and let us know how you're getting on?
Cheers
David
Message 6 of 11
Hi, Uninstalled BT Norton and did a new download from BT site. Still the same problem after new install "Norton Security Pending" and S/W does’t fully install..
Message 7 of 11
Hi @Terry_Artdeco, thanks for trying that and getting back to us.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to look into this error further with you.
Cheers
John
Message 8 of 11
I get the same message and have uninstalled and reinstalled countless times but simply doesn't get past that message.. How did you fix it?
Message 9 of 11
Hi - were you able to fix this issue? I'm getting totally frustrated
Message 10 of 11
Hi @FlyingScot26 and welcome to our community.
I'll be haoppy to take a look at this for you also. Please check your inbox for my message and drop me a reply with the details.
Cheers
David
