This is most likely a very typical problem, as I've seen other people make an exact post about this, but I simply cannot turn it off. I contacted support about this like a month ago, it was turned off for a very short while and then turned on. I have "disabled" it in the BT app settings, it is still turned on.
All websites that are blocked show this:
(SSL_ERROR_RX_RECORD_TOO_LONG)
Yes, using a VPN obviously gets rid of it, but I'd rather not use one. (Randomly times out and such). Using a custom DNS in Firefox itself also works, but that doesn't affect websites out of the browser. I've tried to use 1.1.1.1 but that didn't seem to work, as well as Google DNS.
Is there someone who works in the backend who could possibly look at this?
From what I can tell BT's web protect doesn't work at the DNS level (though it can work with/alongside it) but rather at the IP level. This is why innocent sites sometimes face issues when hosted on machines which also host slightly more dodgy sites. If you haven't already done this, I'd use a browser other than firefox to turn off Web Protect. Using other browsers, you'll usually get a page telling you when a site is blocked.
*Using Ad-Block Home (small list) with parrallel BT, Cloudflare, and Quad 9 DNS, all on their web-protect or equivalent settings.
Yes, you are right, DNS no longer really works, I remember it used to work on EE a couple years ago.
Although, I thought of a way to temporarily bypass this error. If you use "curl", or anything else that can do web requests and ignore SSL. You are able to get the proper redirect and your own token to allow the website. Shown as here:
(I don't think there's a point of censoring the token, it's very short and I doubt much can be done with it)
When you go the the page, you'll obviously see the generic thing saying it's a scam, however you are able to click "Continue away", whitelisting the domain for a short while!
Although, this is just a very stupid workaround, I still really need this disabling.
Hi @kendality
Whilst we recommend keeping Web Protect activated to keep your browsing sessions safe and secure, if you'd like it to be turned off I'd recommend giving our Customer Service team a call who'll be able to manually deactivate it for you again.
They'll also be able to raise a ticket for your account to be investigated as to why it switched itself back on as well as why you're unable to control it through the app as expected.
Ali
Alright, I'll try that.
