Message 1 of 6
Device security - Behavioural Protection
I`m getting a message to say that I am at risk - Behavioural Protection will not update.  I`ve done the Live Update countless times and restarted the computer , all to no avail.
Can anyone help please.
5 REPLIES 5
Message 2 of 6
Re: Device security - Behavioural Protection
Can’t say I’ve ever heard of “Behavioural Protection”?
I think you’ll need to give people more to go on.  Like, what app is it?  What operating system is the computer running?
Message 3 of 6
I'm guessing you're talking about BT Virus Protection ?
If so, see this link Message: "Your PC is not protected by Behavioral Protection" (norton.com)
Message 4 of 6
Ah, Norton.
Not used that for years.  Sounds like what they used to call heuristics.  Probably a false positive then.
Message 5 of 6
Reinstalled Norton which sorted it. Thanks for your help.
Message 6 of 6
Reinstalled Norton which sorted the problem. Thank you
