Message 1 of 3
Ducting
Hi
we are in the process of building some new build properties and have a question about the ducting that we have installed for bt fiber.
can this ducting be used by us to run cat6 cabling for a gate entry system? As well as the fiber line?
many thanks
2 REPLIES 2
Message 2 of 3
Re: Ducting
Good morning.
Only Openreach would know the answer. Check out this guide from them on how to install underground duct.
https://www.openreach.com/content/dam/openreach/openreach-dam-files/new-dam-(not-in-use-yet)/documen...
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
Re: Ducting
If OR supplied the duct on a ‘proper’ newsites basis , so contracts signed , site has an Openreach new-sites rep /field based coordinator etc, then probably no , although you install it , it’s for OR use , however if you were a Alt Net and had entered into a PIA arrangement you could ‘share’ the duct .
