Message 1 of 3
Install BT Virus Protect
I have Norton 360 and Norton Password Manager installed on Windows 10 PC, and mobile devices using Android.
Do I need to uninstall these before adding Norton for new BT Virus protect ?
2 REPLIES 2
Message 2 of 3
Re: Install BT Virus Protect
You do not need to install BT Virus Protect unless you want to.
The Norton 360 and Norton Password Manager that you already have installed is all that you need.
If however you did want to install the BT product you would need to uninstall Norton 360 and Norton Password Manager.
Message 3 of 3
