Message 1 of 1
Mounting BT Cloud as a drive
Hello.
Does anyone know, or had success in mounting the cloud allotment as a drive?
I have the application called Mountain Duck and I have been trying, unsuccessfully, to mount my cloud storage as a drive. I have it set to WebDAV(HTTPS), using port 443 with what I believe are the appropriate URL/Paths and my login credentials. Connect mode is set to Smart Synchronisation, though the two other options available give the same error.
When I try to connect I get an error, listing directory/failed (404), unexpected response, and a message to contact the service provider.
I'm scratching my head trying to think of what more I can change or what information I might have given it that is incorrect
Is there anyone out there who knows what I'm doing wrong or if what I'm trying to do is even possible?
Ihanks.
