Message 1 of 10
My BT app Speed Test
On the latest app they have updated the speed test but it keeps stalling after the download test and stays stuck on the almost there page. Anyone else having this?
Tags (3)
9 REPLIES 9
Message 2 of 10
Re: My BT app Speed Test
You don’t need to use the MyBT speed test, just use any available such as fast.com. The BT speed test in App won’t be any better or worse.
Message 3 of 10
I have always been a bit sceptical of ISP's own speed tests i prefer this one, let it run for a minute don't take the first download speeds result as final  it does it in three stages,   it also gives  lots of detail about your connection as well as its speed.
(not shown in screen shot below)
https://speed.cloudflare.com/
Message 4 of 10
Yes, Speedtest does same for me. Lately the page said BT is aware of the problem and trying to fix. Today 14 Nov the message is no longer there but Speedtest hangs with nearly there message.
It is debatable whether BT is doing the right thing- myBT now asks you to give it Router sign in details so the app can access it and you have some but not all details that you got by signing into the router management page. In my mind this is not as safe as before where only the customer has these once changed from factory default.
BT’s fault reporting doesn’t appear to check the broadband speed or at least it doesn’t tell you what they are. Annoyingly it asks you to tun on your 2.GHz Wi-Fi. I don’t want to because it upsets some of my devices and I prefer to have a 2.4 GHz hotspot via a third party device, with a different SSID. Why should BT care whether I use 2.4 GHz.?
Most alternative speed checkers people recommend do not really check the braodband speed, they give you a WiFi speed to your device. A 900 ish Mbits/sec download speed on fibre is too fast for most iPads/ iPhones connected via Wi-Fi, they are typically limited to about 4-500 Mbits/sec if within à short distance to the router. These devices cannot be connected by wire to the router easily, and if  connected, usually are limited to slower speeds than the Wi-Fi connections. You need a fast laptop/desktop connected via an Ethernet cable to handle the full speed, and then the third party tests may approximate the broadband download speed. The fact that Bt used to do à special loopback type test that allowed it to measure the broadband fibre speed from its servers to the customer’s router (excluding Wi-Fi  speed from router to device) is valuable and allows customers to see if BT is complying with its performance obligations, and could be executed via iPhone/ iPad via Wi-Fi. Come on BT, get your act together.
Message 5 of 10
As that is the way 99% of us connect  our devises surely that's the number we are looking for, I get that if you have a dispute over your speed and it's falling below the minimum guaranteed you need to connect by Ethernet  to get the actual speed  but as I said for 99% the speed test is accurate enough.
Message 6 of 10
If you are on FTTC or ADSL, your router stats give you the broadband speed .
As FTTP isn't rate adaptive, the broadband speed is the speed you are contracted for. It is extremely rare for a fault condition to cause slow speed. Fibre either works or it doesn't.
Message 7 of 10
I may have this wrong and am not trying to teach my gran how to suck eggs (as the old saying goes)  but i was under the impression from reading a recent thread here that Wi-Fi has a speed limit our current routers wont go above.
Message 8 of 10
Smart hub 2 and previous do not really provide a broadband speed stat, I don’t think.
with FTTP on smarthub 2 might tell you the “WAN speed” - which is really the Ethernet clock speed out of the router and between the ONT modem and BT network servers. For me this is 1000 Mbits/s but the guaranteed speed is lower, reflecting the realities of latency, handshake time, server load and response etc.
so whilst not being rate adaptive in that sense, the fact that ISPs have a guaranteed (minimum) speed reflects that it will be/ should be between that and à theoretical maximum, I.e. at or above the contracted rate.
if the speed was always the contracted rate, Bt could get away by looking up the customer contracted profile and simply say “ Your contracted speed is xx” without doing a speed test. I would still like to see BT fix the speed test!
Message 9 of 10
I am getting this on my 150 Mbps Wi-Fi connection all over the house so i am very happy i moved from TalkTalk to BT.
Message 10 of 10
@FredT  The Smart Hub 2 provides download and upload DSL speeds along with noise margin figures for both. The Smart Hub 3 doesn't provide the noise margin figures but still provides the DSL speed.
As stated previously, unless there is a very rare fault, your line speed will be the contracted speed.
On FTTP, the hub merely reports the Ethernet link speed between ONT and Hub which will be 1Gbs. It will report that with the fibre disconnected.
