Message 11 of 22
Re: MyBT login everytime I open it
Hi again @sdrew1, what you've mentioned here definitely doesn't sound right.
What device is it you're accessing My BT from, and this fully up to date?
I use it myself regularly, and it should only be asking you for the full login details again if there's a significant update.
Peter
Message 12 of 22
Windows 11 laptop. However, this afternoon after speaking to a guide on 150, The box for the Norton password vault master password opened fully and I was able to log in rather than keep going round in circles between the log in page and the password manager access page. I think the chap I spoke to might have sorted it. I have just checked again, going to Norton password vault and not the BT app and it has given me the master password access box. Before, it was going to the MyBT login screen. So it is aok and I hope it stays that way. I use it on the iPad also but you get a split screen for the mail on there, and I had just purchased an item with a guarantee and wanted full screen to print hard copy to place with the instructions. Didn’t expect to spend nearly a day sorting out the tech to do it with! Thank you for your comments.
Message 13 of 22
Android, Motorola Edge 20
Message 14 of 22
@sdrew1 When you are finished with the app are you clicking the log out/sign out button or do you just minimise out the app and swipe it closed?
Alex
Message 15 of 22
The latter
Message 16 of 22
@sdrew1 Do you have any other phones in the house as you could try installing and logging into the app on another phone and see if the issue happens then? That will help confirm if this is a device specific issue or something account related causing it.
Alex
Message 17 of 22
It is now working properly on the computer. I have never used it on my mobile, only computer and iPad.
Message 18 of 22
I had a good spell of about a week and this morning the dreaded enter email address screen is back.
It is so frustrating
Message 19 of 22
And at the very least if you will not or cannot fix this bug, please please let me use google password manager directly when entering password
Message 20 of 22
Hi @sdrew1
Have you taken any actions to clear the cache of your apps recently?
Please also ensure your phone has the latest version of the app.
Should you have the latest version and you are still experiencing these issues please get in touch with our technical care team who can investigate this further.
Thanks,
Katie
