Message 1 of 1
Norton - how do I remove it?
I installed it, seemed OK initially despite some problems updating the database. However, now it seems to be slowing down a few operations quite considerably.
I cannot find anyway to uninstall. The instructions on Norton are incorrect as it says go the Apple Menu and select Uninstall.
On the BT Website is says "we don't recommend it", but here is a way to remove other software.
Does anyone have a solution - other than "drag it to the bin"?
UPDATE : SOLVED IT. I'll leave this here in case anyone else has the issue. It is actually a bit smarter. Drag the app to the bin, this triggers an uninstall app to launch and restart.
Tags (2)
