Message 1 of 3
Norton security and Google Chrome
26-01-21
After receiving a letter from BT that indicated that BT was moving from McAfee to Norton, today, as instructed I updated my laptop to Norton but I have run into the following problem. I now find that when using Google Chrome the small green circle indicating that a web site is safe (or, presumably, some sort of red symbol for an unsafe site) is now no longer displayed.
Any advice as to how I can remedy this problem.
2 REPLIES 2
Message 2 of 3
Re: Norton security and Google Chrome
The dots you are talking about will probably have been a McAfee browser add on which will obviously not work if you no longer have McAfee on your system
Norton offer a similar browser addon.
See link
Add or install the Norton browser extensions to your browser
Message 3 of 3
Message received and understood.
Thank you for you time, trouble and prompt reply.
