Message 1 of 5
Parent control
Hello,i have the bt mobile app however it will not allow me to set up parent control on how long a device can access Internet on each device.
Can anyone help?
4 REPLIES 4
Message 2 of 5
Re: Parent control
Message 3 of 5
Re: Parent control
Hi,thanks I have, It tells me to download bt app which I have done all other controls work except the one that controls the time of a device being connected.Im doing this on a samsung mobile not sure but it's definitely a fault.
Message 4 of 5
Re: Parent control
Hi @Ss23,
Welcome to the BT Community
I would recommend reaching out to our technical team for some support, they will be able to take a further look into it for you and if its still not letting you setup the control timers they can raise the fault to help get it sorted.
Alex
Message 5 of 5
Re: Parent control
Update i reached out to support team and its been resolved i just needed to add the disk set up on app!
