Message 1 of 2
Parental Controls not activating and blocking safe sites
Hi.  For the past week or so every time I attempt to use access the web, I get a message telling asking me to active my parental controls.  It then blocks the page.  This is extremely frustrating as I work from home and need to access hundreds of different sites everyday.
I've logged on to My BT account several times to active the setting, but every time I get the same message 'Your services will active in the next 2 hours'.  They never do.
Please help.
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Parental Controls not activating and blocking safe sites
Hi @scanning161, welcome to the forum, and thanks for posting about the Parental Controls.
Would you check that the Parental Controls are showing as Active by logging into your BTID?
cheers
John
