Message 1 of 5
Possible to cancel Hybris Connect?
Is it possible to cancel my hybrid connect? Not had to use it since getting connected a few months ago and would like to switch to 3rd party router which isn't possible with hybrid connect.
4 REPLIES 4
Message 2 of 5
Re: Possible to cancel Hybris Connect?
If you have it as a monthly addon, you cease it with 30 days notice and send it back.
If you have it free with Halo 3+, you would need to switch to another broadband promotion or just keep it in case you need it, it's free with Halo 3+
Message 3 of 5
Brilliant,  thanks Richie it's an add so will cancel it and send it back.
Message 4 of 5
I assume you don't require a phone service as  Digital Voice won't work with a third party router
Message 5 of 5
Hi locquorice, no we don't have a home phone.
