Message 1 of 25
Security warning when accessing the Hub Manager
Since 13 December2025 new Firmware up date  when logging  into BT HUB warning
Security Warning on Browser
Have had conversations with BT  Technical first was reported 20 th  December2025
with this is a temporary situation to Today 2 months later  a complete change  of this is a error from Browser
 WITH NO interest in fault
24 REPLIES 24
Message 2 of 25
Re: Security warning when accessing the Hub Manager
Message 3 of 25
Hi thanks for replying clicked on link but not sure of suggestions was it use Safari Browser
Message 4 of 25
No. The suggestion is to ignore the warning as you are using it to access something known on your own private network ie the hub manager.
Message 5 of 25
@paulpablo   Read messages 11 and 12.
Message 6 of 25
hi again
 I know the message to ignore the warning which i have been informed numerous times
But the Idea of this blog is to ask fellow bloggers their concerns & BT negative response as only was a result of last  Firmware update 13 December 2025
Message 7 of 25
hi WSH
 can you confirm 11 /12 page as only goes up to page 8
thanks
Message 8 of 25
He said message not page!
Message 9 of 25
Yes, it was message 11 & 12 not page.  If you look just above this, you will see it says message 9 of 9.
Message 10 of 25
Or in this case, message 10 of 10.  (Not sure how I managed to post that twice).
