Message 1 of 6
Unable to disable public Wi-fi on Smart Hub 2
Hi all,
This seems to be a common problem. I can find no way to disable public wi-fi on my smart hub 2. I rang in to 150 and was told it is not possible, but I find that hard to believe (and didn't really see any point in arguing).
Has anyone found a way to turn public wi-fi off? If it makes any difference, my last firmware update was 15 Oct 2022.
Thanks in advance
5 REPLIES 5
Message 2 of 6
Re: Unable to disable public Wi-fi on Smart Hub 2
It can't be turned off in the hub, you need to turn it off in MyBT. However, you may have noticed in the previous thread that there is currently a problem with the web page. https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/Unable-to-disable-BT-Wi-Fi/td-p/2257928
Message 3 of 6
Thanks.
Perhaps if a moderator see this, they can help as they offered to do on the thread you linked. Let's see.
Message 4 of 6
Have you actually tried the methods posted in @licquorice link as they may actually work for you
Message 5 of 6
Yes, I tried all the suggestions but they didn't help.
Message 6 of 6
Never quite understand why the need to turn it off. It's quite a useful feature to be able to take advantage of it whilst out and about which you won't be able to do if you disable it on your account.
