Message 1 of 2
WhatsApp on BTWiFi
Cannot answer WhatsApp calls when on BTWiFi. Works correctly away from home address.  What is the solution?
1 REPLY 1
Message 2 of 2
Re: WhatsApp on BTWiFi
Hi @BrianAlecT.
Thanks for coming to the community.
If this is happening on your home Wi‑Fi, it’s worth checking a couple of settings on the BT Hub. Smart Setup can sometimes interfere with how apps connect, so turning that off is a good first step to see if it helps. It’s also worth having a quick look at any Parental or Content Controls you’ve got enabled, just to make sure nothing there is restricting the connection.
Debbie
