Message 1 of 2
MyBT app WIFI controls problem
Since the MyBT app updated I am unable to access the WIFI controls under parental controls anymore which is really frustrating for me as someone with 2 internet curious children.
I used to be able to utilise these controls on the old app, now however when I go to the parental controls section the WIFI controls button says 'please download the My BT app' even though I am on the app! What is even more confusing is that all the other options like 'virus protect' above wifi controls work fine and allow me access to those features.
I have tried re-downloading the app and uninstalling and reinstalling the app but the problem persists. Any advice appreciated.
1 REPLY 1
Message 2 of 2
Re: MyBT app WIFI controls problem
Hi @rsmith1186.
Thanks so much for coming here.
If you are unable to access your parental controls please give us a call.
Our technical care team will be able to take a further look into this.
Katie
