Message 1 of 5
parental controls stuck on
turned on parental controls, everything was super slow so i decided to turn it off but the dialog box for activation is still showing activate. cannot turn off safe browsing as well please help
4 REPLIES 4
Message 2 of 5
Re: parental controls stuck on
Good morning @sathyanarayanan, welcome back to the BT Community!
If you haven't already, can you please try connecting to the browser version of My BT from a different device or browser, whilst still connected to your network?
If this still isn't working, I'd recommend reaching out to our technical team, and we can take a closer look into things from there.
Peter
Message 3 of 5
i've tried it from different devices and it's still stuck on
Message 4 of 5
also the message us button doesnt work
Message 5 of 5
Thanks for giving that a try, @sathyanarayanan
What's happening when you try and use the messaging option, this will initially connect you with a virtual assistant, but this should help route you to a member of our team once we've done some checks.
If this isn't working, it's also possible to give them a call on 150 from a BT phone, or 0330 1234 150 from another provider.
Peter
