Message 1 of 7
windows firewall
Hi,
Should I enable windows firewall even if I have Norton virus protection?
6 REPLIES 6
Message 2 of 7
Re: windows firewall
  • Yes, if you only have Norton AV.
  • No need if you have Norton Internet Security. That will manage the Firewall.
Message 3 of 7
Thanks for your speedy reply.
Would this be the Norton security I downloaded to replace McAfee as instructed by BT?
Thank you
Message 4 of 7
Yes, that'll be my 2nd.
Message 5 of 7
Thanks, but, sorry what do you mean -  "that'll be my 2nd" . . ?
John L
Message 6 of 7
I think the Baron meant the second bullet point in his post.
You would be just as well protected by simply using Windows Defender and ditching Norton.
Message 7 of 7
Thank you for your interest, "pottyperson".
Only when you've got the time and inclination, I would be interested to know why I " would be just as well protected by simply using Windows Defender and ditching Norton".
John L
