Message 1 of 6
BT Pro Box pause/rewind
Hi All,
Weird experience. I paused a pgm to do something else 😉,  when I resumed and came to FF the adverts, the > arrow rewound the pgm rather than go forward?  Obviously I tried the < button, and lo, it advanced the recording???
Any ideas, I have done the remote reset (Home and 9)?
5 REPLIES 5
Message 2 of 6
Re: BT Pro Box pause/rewind
OK, I'm going to have to ask the obvious ...
There's no chance you had the remote upside down is there?  😁
Message 3 of 6
Hi @DarrenDev   😂  No, and to the next obvious q, no I hadn't been drinking either.
Message 4 of 6
Hi @DarrenDev  - FYI in case anyone else experiences it
 The following day the only button responding on the remote was the  vol up/down. Did the obvious battery change, remote reset, but it was fixed by a reboot of the Pro Box.  Been fine since. 🤷🏻‍♂️
Message 5 of 6
Did you manage to sort this out, having the same issue.
It's not the size of the wand but the magic in the stick.
Message 6 of 6
@curlywatts Hi, yes as above I rebooted the Pro box (not a factory reset).
