Message 1 of 2
BT Pro internet picture
Why is the BBC 1 HD picture so bad? It seems to be worse than an SD picture but clearly says HD?
1 REPLY 1
Message 2 of 2
Re: BT Pro internet picture
Hello @Caher thank you for your post today 😀
What TV box do you have?
You might find this link helpful:
https://www.bt.com/help/tv/getting-set-up/bt-tv-user-guides
Can you confirm if it’s the same with any other cancel or with a different HDMI cable?
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
