Message 11 of 23
Re: BT TV App not allowing recordings to be set
I actually did a full reset this morning as BBC IPLAYER was having issues. I've posted about this also.
Iplayer is resolved but recordings via the app are not!
I've only had the box 2 weeks and app recordings have never worked.
Message 12 of 23
I'd love to get additional information from you both @PJCORNELLY @Ronny101 if you don't mind?  I'll send you both a DM with instructions on how you can enable additional logging, so that I can get full details about what your box is telling the app.
Message 13 of 23
@DarrenDev  Thanks, I’ll try the maintenance reset and feedback.
Message 14 of 23
That’s ok Thanks - I’ll try a maintenance reset first.
Message 15 of 23
@PJCORNELLY I don't have any option to send you a DM - I'm guessing you've turned them off?  Could you please either send me a DM, or email me at tv.apps@bt.com so that I can provide the instructions.
Message 16 of 23
@DarrenDev sorry I meant yes ok to DM but I will try a reset before
Message 17 of 23
Not sure about DM quite new here. Email sent.
Message 18 of 23
Success 👍 Maintenance reset worked for me😁
Re-paired both devices following reset and both sending requests, being received on the box and working as expected. Many thanks for all the support from the community. Apologies @DarrenDev I couldn’t help with your error logs and @PJCORNELLY  hope you get yours working too soon👍
Good luck and Best Regards
Message 19 of 23
@Ronny101 that's goods news. 👌
Anyway I've been faffing about today tidying cables etc and in doing so powered everything off at the mains for quite a period of time.
I reinstalled the BT app on my phone repaired and now it's all working with me too!
Just awaiting the maintenance software update now. 🙄
Message 20 of 23
I am having the same sort of problem. Unable to view or set recoding on by BT Pro Box on mobile app as getting message about software upgrade required on box. I have carried out a factory reset on box, and repaired mobile phone. No difference . Is maintenance  software update any different too factory reset ?
