Message 1 of 3
BT TV Remote weirdness
Anyone having issues with their BT TV Pro remote today ?
 The up/down/left/right works fine on the menu, selecting apps, recordings etc - but does not work on the TV Guide 😞
Volume / Power / Mute etc all work fine.
I've unplugged the box at the rear and power cycled it - to no avail
2 REPLIES 2
Message 2 of 3
Re: BT TV Remote weirdness
Sorry - it appears I might have posted in haste.
I checked for updates, and the box decided to reboot (guessing to apply them) ..
Upon restart I have a different looking TV guide, which now works 👍
Leaving post up in case it helps others
Message 3 of 3
Thanks for coming back and letting us know @Mark
Have a great day,
Katie
