Message 51 of 55
Re: Bt pro box unable to set record for 1day
@scharter It’s a service provided by Global( the owners of LBC) online or on an app whereby you can either listen live or on catch up to their radio channels, of which LBC is one. Others include Classic FM and Capital.
Message 52 of 55
@sthwestguy
It's unclear from your post whether you are referring to the issue with the LBC recording not existing on an different model box or the date issue last week. Can you confirm please?
Message 53 of 55
@rbz5416  LBC Channel on the pro box all sorted now working
Message 54 of 55
Sorry, what I'm trying to establish is when you verified that the problem with LBC also existed on your Pro Box, did you then test it with the other box? If so, what was the result?
Message 55 of 55
@rbz5416  I tested retail Humax youview box first was ok so knew pro box had issue
