Message 1 of 8
Can't find BT TV on BTTV PRO box
I have a bit of a problem just got BTTV set up via WiFi  but I cannot find any BT TV channels on my box only freeview and NOW tv  is there something I'm doing wrong
7 REPLIES 7
Message 2 of 8
Re: Can't find BT TV on BTTV PRO box
Confused, what BT channels do you want?
If you have Freeview and now TV and AMC that's the channel offering.
Message 3 of 8
It says they offer euros port  BT Sport BT Store AMC can only get freeview and NOW tv
Message 4 of 8
If you subscribe to BT sport it should be Eurosport is included with that.
AMC should just be there. Check your account if it's not activate it.
Message 5 of 8
To add AMC HD is channel 381
Message 6 of 8
Which TV package do you have?
Message 7 of 8
Good morning @Dan20153  it sounds like you may have a couple of orders in progress and your TV box has arrived before your broadband has been set up.
That means that you won't see the available channels as the TV box is not connected to an active BT Broadband line.
I will send you a Private message to ask for your account number and any order numbers you may have been sent so we can find out what stage the orders are at and advise on next steps.
Thanks,
David
Message 8 of 8
Haven't got any order numbers as I ordered it over the phone
