Message 1 of 2
How do I order bt tv pro box
I have had an engineer he said mini WiFi extenders are being phased out. And to check on a bt tv pro box. How do I order one
1 REPLY 1
Message 2 of 2
Re: How do I order bt tv pro box
Hi @taffman633, welcome to the forum, and thanks for posting.
I'm not aware of any imminent change that would stop you from using the WiFi extenders. If you would like to find out more about the Pro Box check out How It Compares With Our Other BT TV Boxes.
If you want it then you can give us a call and our sales team will be happy to help you.
cheers
John
