Message 1 of 2
NowTV Sport, can I use another login?
I’m now on NowTV with BT. I have the entertainment pack so get those NowTV channels.
So am I correct to say that I can now switch on NowTV (Sky) Sports for a month, and switch off month to month, and this allows me to record? How do I switch it on, then switch off, via BT app?
As using it via BT it will be the full price £33.99. Before having NowTV via BT they always used to give offers for Sports, like half price for 3 months etc.
If I want to do this, giving up the option of recording I know, can I just sign up separately with a new NowTV account and use that?
1 REPLY 1
Message 2 of 2
Re: NowTV Sport, can I use another login?
You can either use the flexible passes available through BT but these will be charged in line with BT's packs. Doing it this way will allow you to record and you can watch the recordings as long as you maintain the relevant subscription.
The other option is to set up a separate account through NowTV and buy passes directly through NowTV but you will not be able to watch via the BT TV EPG. So it will be app access only.
