Message 1 of 3
Pro Box IR Remote Support?
As I understand it the Pro Box uses Bluetooth for remote control. This is an issue for me as although my Harmony remote will support BT, Logitech have pulled the plug & are unlikely to be adding support for the Pro Box.
However, I've seen several references to using the "old" remote. Is this an older version of remote originally supplied with he Pro Box, or does it also support the Humax IR codes of the earlier boxes?
2 REPLIES 2
Message 2 of 3
Re: Pro Box IR Remote Support?
The Youview Humax/BT remotes that were supplied with previous box models eg 1000, 2000, 2100 , 4000 series can be used  control the Pro box but will need to operate within line of sight of the box.
Message 3 of 3
Thanks, I've had chance to test this now & can confirm it all works with the Harmony Hub. 🙂
