Message 1 of 7
Pro box connection
How do you connect a pro box without an aerial or ethernet but with a mini connector?
6 REPLIES 6
Message 2 of 7
Re: Pro box connection
Again the Pro Box will connect via wi-fi, have you not tried?
Message 3 of 7
I am trying to find out how to do that. But then I am not the brightest technically.
Message 4 of 7
There's a step by step guide here. Start by clicking on wi-fi and follow instructions:
Set Up EE TV box pro | BT Help
Message 5 of 7
BT is sending out an engineer as they can't connect it either. Thanks for your help.
Message 6 of 7
I assume by "mini-connector" you actually mean (full-size) HDMI connector, and I'll lay odds your new TV does indeed have one of these!
I only learn by making mistakes and owning up to them - boy do I learn a lot!
Message 7 of 7
Mini-connectors used to be called power line adapters. They are plugged into a wall socket and one is upstairs where the hub is and one is downstairs where the TV is. HDMI connector is a cable and it has a connector site on the TV.
