Message 11 of 20
Re: Recording Eubank vs Benn Sky Sports Box Office?
@Christopher_Gwrote:
I'll see if I can find out for sure, @naylor2006
Chris
Hi Chris.
Did you manage to get any information on this point?
Thank you.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 12 of 20
Hi @Splinx
There is a script to help on the UDM type devices...
GitHub - fabianishere/udm-iptv: Helper tool for configuring routed IPTV on the UniFi Dream Machine (...
Pretty sure you only need to worry about step 5 but do check it all out.
I cant provide specific config for UDM (Unifi) type stuff because they are a little different to the ER-X (EdgeMax) because on the latter you can mess about with them more like an enterprise router, the UDM are being configured via Unifi by the vast majority of users, luckily you still can take SSH and run a curl on it like in that link.
Not seeing much success with people getting IPTV to work over WIFI on Unifi gear, I never tried and people I know using this script just used ethernet, I would recommend the same, even though I dont rate powerlines, if its the only way to get ethernet to the EETV box then so be it.
Message 13 of 20
@naylor2006 Thanks for coming back to me mate (and sorry for hijacking this thread). I will rewire my dad's house (even though it means crawling underneath it) and try again. it's frustrating as I can see that others with the UDR7 (the latest pill-shaped one) have seemed to get it working and I'm no noob - I just must be losing my touch 😞 Either that or BT have updated things in light of their recent move to integrate normal phonelines into the hub/VOIP? I'll report back later this week. Thanks again.
Message 14 of 20
Digital voice shouldnt be effecting it, I just personally havent seen anyone report it working on Unifi wireless....and where I have seen it work its with that script from GitHub. Luckily my TV box is in the same room as the router so I dont need to use wireless, although I do have ethernet throughout so could utilise VLANs, make a IPTV VLAN and tag it so itll find its way to the device on an interface somewhere else. I think VLAN's can help with wireless IPTV, so you have a given access point with a VLAN attached to a specific SSID, that way only things connecting to that SSID will get the multicast packets.
Anyway, if you want to get IPTV working you have to ensure its working via ethernet first before tackling WIFI, usually you have to designate some dedicated interface for the IPTV also.
I think really for some people it just works, and others have to muck around with it, definitely the most solid setup is using the Edgemax stuff where you can bake it into the config file natively.
Message 15 of 20
Hi @naylor2006
I've been speaking with the EE TV team, but they can't give me a definitive answer until the scheduling is released for the event. I'll pop a message on hear as soon as I have something concrete for you.
Chris
Message 16 of 20
Hi @naylor2006
Sorry for the delay in getting an answer to this.
23:59 3rd May is last chance to playback any recordings on the event. Event repeats are the day after the event only.
Chris
Message 17 of 20
Thank you @Christopher_G
So as long as I start watching it around 7pm on the 3rd there should be no issue with that then?
Thats how I understand it.
Message 18 of 20
Yes, as long as it's finished by the cut-off time, just to be sure, @naylor2006.
I'd hate for it to cut off on you before you've finished watching.
Enjoy the fight 🙂
Chris
Message 19 of 20
Yeah we’ll be okay, can fast forward all the between fight stuff.
thanks so much!
Message 20 of 20
Soooo...after the incubus gig at the o2 I was able to make it all the way back to my airBNB without seeing any news of the result, I decided to just buy the fight on DAZN and watch the event that way, as it turned out my mate cant even come over saturday anyway.
Really happy for Eubank.
Appreciate the help here though.
