Message 1 of 2
Returns Label , How to get another one
How do I get another return label to return some old BT kit. The label that was sent with the bag didnt scan so I need another label. Or is it possible to download a label so I can print it off . Thanks
1 REPLY 1
Message 2 of 2
Re: Returns Label , How to get another one
If you call BT 0330.1234.150 you can request that they send one out to you.
