Message 1 of 1
Unable to dismiss privacy policy popup
If you have encountered this issue, where a privacy policy pop-up has appeared, and you are unable to dismiss it, use the following steps to resolve:
  1. Press the helper guide button
  2. Press back
  3. You should now be able to press Ok and dismiss the pop-up
