Message 1 of 35
Will and EE TV BOX PRO WORK WITH VODAFONE Home Fibre Connection?
I like the spec of the box, the internal WiFi connection and have used when EE was my home fibre provider.
Now my home provider is Vodafone....if I buy one of these boxes will it still work?...I have heard some say yes and some say no.
Obviously any specific EE TV packages will not work...but regular Freeview recording?...are the usual catch up Apps all available like iPlayer ITVX etc?...and will the 7 day guide work?
I don't think this box is sold outside of the EE framework.
34 REPLIES 34
Message 2 of 35
Re: Will and EE TV BOX PRO WORK WITH VODAFONE Home Fibre Connection?
it may work but none of the subscription stuff will
just get a  freely box and  connect it to tv
freely box
Message 3 of 35
Yes, recordings and most apps will work fine, however the TV Box Pro remains the property of EE at all times (even if you believe that you bought one legitimately), so there's no guarantee that it'll continue working in future.
You'd be better buying a box that is intended to be sold standalone - e.g. as @shakey1981 has suggested
Message 4 of 35
Thanks for the reply, I have a Manhattan T4 currently and its dreadful, was hoping to go back to the BT/EE one...
It seems from answers across the internet that it will work.
Message 5 of 35
these remain property of bt and are not souppsed to be resold there for if EE fnd out this has been sold they may be able to block its use by an ota update up to you but i would not chance it
Message 6 of 35
The aging pro box is basically just a freeview pvr
It'll work perfectly with freeview and any subscription services you pay for including sky sports through now in UHD...something which EE subscribers are denied
Ignore the Freely suggestions as it cannot record and never will do ...something considerable to consider if you're after a pvr
Message 7 of 35
you dont need to record on a feely box you have catch but anyway it their choice my answer was perfectly valid
Message 8 of 35
A freely box simply isn't an alternative for a pro box
The OP clearly mentioned recording freeview
Also freeview and freely are not the same the latter missing many freeview channels
The only real decent freely box is the manhatten areo which doesn't even have now tv
Also
Since the dawn of time BT/EE youview boxes have been available on ebay, cex etc.
If EE were going to sabotage them surely they would have done it by now.
Message 9 of 35
Thanks all have just bought the above, the seller again says it will work with the exception of an EE TV package.
Will update to confirm all is well once received.
[Mod: link removed]
Message 10 of 35
@BhfpkiiL1 My understanding is that the Pro tv box does not currently support Sky Sports  UHD via the NOW app even if you have a direct subscription with NOW. If you want to enjoy UHD you would need to use a device which supports it.
