Feedback on the BT Calendar
When adding a new entry or viewing an existing entry, the number of lines visible in the "Description Field" is only 3.
If you do add more than 3 lines of detail to your Calendar entries and then want to review the text there, it's a real pain. I'd liken it to trying to read a page of information through a letterbox
Yes there is a scroll bar but you can still only see 3 lines at a time.
Could you please look into increasing the size of the description box to a more useable size? Perhaps one similar to the box I'm currently using for this message? 10 to 12 lines of text visible would be a great improvement
Hi @Ultraviolet13 Thanks for the feedback, what browser are you using and do you have it at 100% zoom?
Neil
It is not the zoom. The box is too narrow and can only reveal a couple of lines of the message without scrolling. The box dimensions need to be increased.
@gg30340 @Ultraviolet13 No worries, I'll feed it back. I'm still on the previous version, so forgive my ignorance.
Neil
Thanks for the reply & no worries if you haven't used the new version yet.
Here's what I get when creating or reviewing/updating a calendar entry. 3 lines visible at one time. Just not enough when adding details to upcoming events.
And, as mentioned, it makes no difference browser / OS / zoom. The visible field size is defined in the software
(But for completeness WIN 11, Chrome, 110%)
