Message 11 of 15
Re: Calendar mistiming
You may find that it is the time setting on the BT Hub that is incorrect. There was a previous issue when it did not change when the clocks changed.
Log onto your BTHub's management pages to see what it is showing.
Message 12 of 15
hi i use he web client
https://www.bt.com/
Message 13 of 15
and how can you check
Message 14 of 15
Login to the hub manager 192.168.1.254 and then navigate to advanced settings>Technical Log> Event log and check the time entered for the login event.
Message 15 of 15
@denvin
Use Home (bthomehub.home)
to log onto the hub management pages. If you want to go to the Advance Settings you need to use the Admin Password shown on the hub's label.
